ODK Build login issue
I am having the most basic of all issues - login works initially and
then after about 30 secs I can not login, even with password resets.
Have tried on chrome and firefox, on ubuntu and windows.
The password reset goes through and emails me a new password, but the
new password doesnt work! Have tried cutting and pasting, manually
typing it in, and just cant figure out what i am doing wrong.
I have made 3 new users and all have had the exact same problem. I
can login and save a form for about 30 seconds, after which I can no
longer login and no longer save work. Password resets go through, but
the new password does not work.
I can try to use purcforms or something more complex, but I think
build is all I need, if only I could save a form!
Any ideas on what is going on here?
Thank you
Gorav
Hi Gorav:
What are the usernames you used when you registered? You're having a pretty odd issue—are you behind a corporate firewall or something else that would be perhaps stripping cookies?
—Clint
Thank you
Gorav
Thank you Clint,
I'm working from home on a really simple cable modem / router. No special
firewall that I am aware of. The rest of the net works pretty well, most of
the time!
I tried clearing the cache, all the basic stuff, and the behaviour continues
consistently. Tried last nite as well as this morning, and everything is
consistent.
the 3 usernames i tried are:
gorav
goravseth
gseth
password reset email comes through fine, but I just cant log in! have no
idea what i am doing that could be causing this, but it totally beats me.
-gorav
··· On Tue, Feb 22, 2011 at 2:13 PM, Clint Tseng wrote:
Hi Gorav:
—Clint
Thank you
Gorav
