I installed ODK Central on my DIGITAL OCEAN droplet. However, when I go to the IP or domain the ODK web panel doesn't show.
NGINX is installed but doesn't appear to be sending the browser session to the ODK control panel.
ERROR: This site can’t be reached [IP_ADDRESS] refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
I verified that NGINX is installed and running.
I would be willing to hire someone to help with the install.
Thank you.
If you want to hire someone, https://forum.getodk.org/c/marketplace/8 is a good place to do that. Our use ODK Cloud hosting.
As to the issue at hand, what happens when you run the docker-compose ps
command described at https://docs.getodk.org/central-install-digital-ocean/#starting-up-central.
I see this...
root@server:~/central $ docker-compose ps
Name Command State Ports
central_postgres_1 docker-entrypoint.sh postgres Up 5432/tcp
enketo docker-entrypoint.sh /bin/ ... Up 8005/tcp
enketo_redis_cache docker-entrypoint.sh redis ... Up 6379/tcp
enketo_redis_main docker-entrypoint.sh redis ... Up 6379/tcp
mail /bin/entrypoint.sh exim -b ... Up 25/tcp
nginx /bin/bash /scripts/odk-set ... Up (healthy) 0.0.0.0:443->443/tcp, 0.0.0.0:80->80/tcp
pyxform waitress-serve --port=80 - ... Up
secrets docker-entrypoint.sh ./gen ... Exit 0
service docker-entrypoint.sh ./wai ... Up 8383/tcp
