Hi ODK Dev,
I recently join the group due to my passion for ODK tools, am undergoing a
study currently and i'm using ODK Clinic v1.0.apk trying to connect it to
OpenMRS ver 1.8.3 using xForms Module. So i was wondering if anyone can
help me go through the process will really appreciate it.
Regards
GibriL Gmz
Hi GibriL,
ODK Clinic is community supported and unfortunately there isn't a lot
of community to support it. Basically, you are on your own. See
https://groups.google.com/d/msg/opendatakit-developers/MTZ94ZiVBm4/n4O8rrQYivUJ
for some ideas about where to start.
On Thu, Mar 6, 2014 at 3:56 PM, GibriL Gmz gibrilgmz@gmail.com wrote:
Hi ODK Dev,
OpenMRS ver 1.8.3 using xForms Module. So i was wondering if anyone can help
Regards
GibriL Gmz
"ODK Developers" group.
Hi GibriL,
Depending on what exactly you want to achieve I could be of help as I
have done quite a number of
implementations.
Sam
On 03/07/2014 08:19 PM, GibriL Gmz wrote:
> Thanks yaw;
> On Fri, Mar 7, 2014 at 5:34 PM, Yaw Anokwa <yanokwa@nafundi.com > wrote:
> Hi GibriL,
> Yaw
> On Thu, Mar 6, 2014 at 3:56 PM, GibriL Gmz <gibrilgmz@gmail.com > wrote:
> > Hi ODK Dev,
> undergoing a
> connect it to
> anyone can help
> > Regards
> > GibriL Gmz
> > You received this message because you are subscribed to the
> Google Groups
> > To unsubscribe from this group and stop receiving emails from
> it, send an
> You received this message because you are subscribed to the Google
> Groups "ODK Developers" group.
> To unsubscribe from this group and stop receiving emails from it,
> send an email to
> *Faith makes everything possible ..!!
> To unsubscribe from this group and stop receiving emails from it, send
> an email to opendatakit-developers+unsubscribe@googlegroups.com
Hi Samuel Mbugua
Thanks for the response, all i want to achieve is retrieving patient from
my OpenMRS installation to the ODK Clinic on my phone to be able to work on
the ODK Clinic and submit to OpenMRS. i have been working with openmrs for
a while but still can't figure out how to go about using the xForm with ODK
Clinic. if anyone can help will be appreciated pls.
regards
GibriL
On Mon, Mar 10, 2014 at 1:19 PM, Samuel Mbugua wrote:
Hi GibriL,
Depending on what exactly you want to achieve I could be of help as I have
implementations.
Sam
Thanks yaw;
On Fri, Mar 7, 2014 at 5:34 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi GibriL,
Hi ODK Dev,
undergoing a
to
help
Regards
GibriL Gmz
Groups
an
