ODK Collect - Location Issue
Hi
I have received this email address if I don't find anything on your website, which is the case.
The issue we encountered with ODK Collect is the following :
When I am filling the form and I want to change the location using the GPS, we got message error : "Unfortunately, ODK Collect has stopped.". Then I thought the GPS doesn't work, therefore I tried an apps using the GPS and it seems to work perfectly. At the end after numerous test we found why it doesn't work. It seems ODK Collect needs a Google Account and you need to run Google Services, otherwise ODK Collect will crash instantaneously when you try to get the location.
For your information, we have Acer Iconia B1-710 running with Android 4.1.2.
So my question is now : Do you think there is another way to enable this option without adding a Google Account ?
Best regards
Pierre TU
Assistant Informatique Réseau et Télécom
Field IT Assistant
ACTION CONTRE LA FAIM
Tél. 33 (0) 1 43 35 86 46
Email : netassist@actioncontrelafaim.org
Skype : acfnetassist
Hi Pierre,
I'm pretty sure ODK Collect does not need a Google Account to work.
Something else (probably specific to the B1-710) is causing that crash
and a stack trace would help the core team try to fix it.
Can you please file an issue at
https://code.google.com/p/opendatakit/issues/list and attach a stack
trace (https://code.google.com/p/opendatakit/wiki/CollectTroubleshooting)?
On Fri, May 23, 2014 at 3:37 AM, NET Assist netassist@actioncontrelafaim.org wrote:
Hi
Best regards
Pierre TU
Field IT Assistant
You do, however, definitely need Google Services for the "maps" and
"placement-map" appearances of the geo-location widget.
If you cannot run that on your device, remove these appearances, and it
should work.
··· On Fri, May 23, 2014 at 6:51 AM, Yaw Anokwa wrote:
Hi Pierre,
Hi
4.1.2.
Best regards
Pierre TU
Field IT Assistant
