Hello,
I am very new to ODK collect. I am just building my 1st survey form. Can
anyone please tell me how I can save an incomplete survey and pull it back
at a later time t complete it?
Thank!!!
Hello,
Thank!!!
Hi, Rubana.
Are you using odk build? if so, to save an incomplete form, go to: File--->
Save or Save as
to pul it back next time, go to:File--> OpenForm and choose your form to
complete on the list.
Best.
What I mean is once I finish building the form and implement the survey,
can I save incomplete surveys (since the time is 1 hour and some
respondents may want to resume after a break) and then work on those
surveys again later?
Hi Amal,
Thanks for taking the time to help me out.
What I meant was once I finish building the form and implement the survey,
Thanks again,
Rubana
Hello,
Yes, at midway in the form when your enumerator gets tire, have him jump to
the end of the form (arrow/dot icon) and then swipe to get to final screen
that says "You are at the end of name_of_form" then uncheck the box "mark
form as finalized" and then save it. It cannot be sent and can be finished
at a later time and then mark it as "finalized" in order to send it.
Curtis
surveys again later?On Wednesday, April 19, 2017 at 12:31:15 AM UTC+10, Rubana Islam wrote:
Hello,
at a later time t complete it?Thank!!!
Curtis BRODERICK
Responsable Assurance Qualité
Health Information Systems
Hi Rubana
It is simple. just tap on back-arrow, then options will come up to save
changes/ignore changes. If you tap on save changes, then the incomplete
will be saved on "Edit Saved Form" to start survey again later.
Hello,
Nurur Rahman Bachchu
Thanks Curtis. I shall try this.
Rubana
Anytime I save my incomplete form that i wish to continue later, some already data entered get missing. I have already started my survey and because of this issue am ale to use the ODK since I cannot complete the survey at a ago.
I am using ODK Collect v1.18.2
ODK aggregate v1.7.1 on windows.
OS- Andriod version 5.1.1 (Samsung Galaxy Tab A6).
Though this topic for discussion is almost some years now, but i cannot find my way out to enable use me continue use this app.
Please, I am counting on this forum for quick response.
Thanks in advance for your support.
