ODK Collect stops working
Hi
I have a probelm where ODK Collect stops working when I open a certain
survey. When the survey opens at first page 'you are at the...' and I swipe
to go forwad, ODK stops working.
Other surveys on the device work properly.
Why ia this happening? Is it an issue in the form?
Thanks in advance.
Louis...
Louis,
Assuming the devices are all exactly the same, then the problem is
likely an issue with the device. Try a reboot and then look at the adb
logcat to see where in the app the form is failing.
ยทยทยท -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
On Sun, Dec 13, 2015 at 6:31 PM, Louis Omoya louisomoya@gmail.com wrote:
Hi
Thanks in advance.
Louis...
