You're using a very old version of ODK Aggregate (1.0.6). While I don't
know of any issue that will cause this in 1.0.6, the first step to
resolving this would be to upgrade to ODK Aggregate 1.3.
Be sure to read the release notes for upgrading instructions (i.e.,
publishers will break)
http://code.google.com/p/opendatakit/wiki/AggregateReleaseNotes
On the website submissions tab, I suspect your dataset is beginning to tax
the limits of how we use Google AppEngine. If I change the number of
records viewed on a screen to '10', I can see data when 'none' is selected;
getting the change to 10 to be applied takes a while - the UI keeps wanting
to reset it to 100.
The CSV export should, however, not have this problem. If there are errors
during the CSV export, you would be able to see them by going to the error
logs for the 'background' version of your app.
Getting to the logs page is described here:
http://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
If there are any errors being reported, please let me know (or invite me as
a developer).
On Mon, Feb 11, 2013 at 11:32 AM, wrote:Hi,
I have an Aggregate instance set up (https://mscantest.appspot.com/) and
created a filter to remove images for export. This has worked fine and
allowed me to see the images for the past year or so, but now if the
submissions are not filtered, I see absolutely nothing, and setting the
filter to no images removes the images that I want to store for reference.If I export the submissions with no filter, the URL in the csv file that's
exported contains the image, but this is a difficult way to look at images.
Any idea where my fields went?Thanks,
Kate--
