Thanks Yaw
I downloaded ODK briefcase as suggested but can't get it to open by any means. I have java 6.
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
Date:14/12/2015 12:18 (GMT+02:00)
To: ODK Community opendatakit@googlegroups.com
Cc:
Subject: Re: [ODK Community] AppEngine Application problem
On Monday, 14 December 2015 09:53:01 UTC+2, Yaw Anokwa wrote:
Hi there,
Sounds like you've run out of quota on App Engine. Wait 24 hours (or
add a credit card to the account) and try using ODK Briefcase to
download the data.
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
As a new user and after a day of failing to get ODK Aggregate to export as a csv or publish my data to Fusion tables so that I could work with it, I got this error:
AppEngine Application Problem
A problem has occurred that prevents your AppEngine application from responding. Your application may have exceeded its per-minute or daily usage quotas.
Please visit your application dashboard at Google AppEngine. The Billing Status section will indicate what daily or per-minute usage limits your application has exceeded.
If your application's usage limits have not been exceeded, then look for performance issues within Google AppEngine cloud services. From your application dashboard, click on the the System Status link on the left sidebar under the Resources heading. This will report problems with Google AppEngine cloud services.
If neither of those indicate any problems, then your application's Logs may; these are reachable from the dashboard via the Logs link on the left sidebar under the Main heading.
Initially clicking the link revealed that an arbitrary Google account seemed to be involved - i.e. one I had set up long AFTER the server was created, for one of our data gatherers, not mine (this one) as the data manager. Logging in using this account and trying to follow that advice took me to a succession of new and confusing places.
I have no idea how to deal with this and hope that someone can help.
I really am getting nowhere with trying to access the data in my ODK collect database, which is presumably being updated by at least 22 records a day.
I can't get ODK briefcase to open at all.
If I try to publish the data to fusion tables using my email address I get this error:
Error: RequestFailureException (org.opendatakit.aggregate.exception.ODKExternalServiceCredentialsException: No OAuth2 credentials. Have you supplied any OAuth2 credentials on the Site Admin / Preferences page?)
> From: umzim...@gmail.com
> To: ODK Community
> Since I have no idea what OAuth2 credentials are, I'm not sure how I would know if I had supplied any? Can anyone help here?
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
P.s. if you are somehow related to the umzimvube municipality in SA, i am
sure we could assist telephonically
> > Oops. I've update our documentation -- it requires java 7 as of ODK
> Briefcase 1.4.6
> > https://github.com/opendatakit/opendatakit/wiki/Briefcase-Release-Notes
> > Thanks Yaw
> > To: ODK Community
> > Cc:
> Groups "ODK Community" group.
> an email to opendatakit...@googlegroups.com.
> a day.
> this error:
> > Mitch Sundt
> > Software Engineer
> > mitche...@gmail.com
