What version of the Android OS is on your device? What device are you
using? Does this only occur when you have two text prompts on the same
screen? If this only occurs when you have two prompts on the same screen,
this is a known issue. Feel free to file an issue at
https://github.com/opendatakit/opendatakit/issues.
Clarice
On Thu, Jun 30, 2016 at 2:11 AM, Werner wrote:Hi
I am currently working on ODK 2.0. I am using Android SDK in a chrome
browser and I am having problems with a simple text prompt. A text field
appears and when I enter info and click next the text field clears before
going to the next prompt.I know it clears since when I made it a required field it kept saying that
the required value was not provided.I don't know if this is a problem with Android SDK or ODK Survey.
Thank you for your time.
