Use the ODK Briefcase application. This allows you to pull all data down to
your local computer. After that, you can Export to CSV. This will produce
one CSV file for the top level group and one CSV file for each repeat group
within the form.
On Thu, Jul 5, 2012 at 4:23 PM, wrote:
When I have a repeating group in a form and I download this form from
aggregate in the multiple entry field I get an http:/ instead of the actual
data. I have attached a copy of my CSV file. Does anyone know what to do to
prevent this from happening and to be able to export the real data?
There is a usage section that explains this on the website
My guess is you are using a google account instead of a ODK account.
On Fri, Jul 6, 2012 at 10:59 AM, wrote:
> On Thursday, July 5, 2012 6:42:45 PM UTC-5, Mitch wrote:
>> Use the ODK Briefcase application. This allows you to pull all data down to your local computer. After that, you can Export to CSV. This will produce one CSV file for the top level group and one CSV file for each repeat group within the form.
>> Mitch
>> On Thu, Jul 5, 2012 at 4:23 PM, <nabil.mansouri@gmail.com> wrote:
>> When I have a repeating group in a form and I download this form from aggregate in the multiple entry field I get an http:/ instead of the actual data. I have attached a copy of my CSV file. Does anyone know what to do to prevent this from happening and to be able to export the real data?
>> Mitch Sundt
>> Software Engineer
>> University of Washington
>> mitchellsundt@gmail.com
> Hey Mike,
> I downloaded briefcase into my computer. But I'm having trouble pulling the info into briefcase. I get this error message:
> Fetching form definition
> Unexpected error: Fetch of /Users/nabilmansouri/Desktop/ODK Briefcase Storage/forms/Multiple.Operator.DropOff.v1/Multiple.Operator.DropOff.v1.xml failed. Detailed reason: Unauthorized (401) while accessing: https://stanfordresource.appspot.com/formXml?formId=build_Multiple-Operator-DropOff-v1_1341426905
> The error message mentions an unauthorized user but I did use my correct login info? Do you have an idea what could be happening?
> -nabil
No, if you need everything in one file, consider exporting to JSON (newly
available in ODK Aggregate 1.2 -- ODK Briefcase isn't able to do this).
This will recursively traverse the form, emitting all nested repeat data
along with the form. The media attachments are referenced as URLs.
On Wed, Jul 25, 2012 at 1:59 PM, wrote:
Mitch,
Is there a way (or java application) that merges the repeat data files
into one csv file?
Mike
Along those same lines, you can also patch Briefcase to export JSON.
> Mitch
>> Mitch,
>> into one csv file?
>> Thanks,
>> Mike
>> > within the form.
>> > Mitch
