Hi Miranda,
I didn't look closely at the form, but I bet the problem is that you
aren't using single quotes around yes. It should be:
if( (${Concentration1} < ${Concentration2} and ${Effluent2_skip} =
'yes'), ${Concentration2}, ${Concentration1})
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Wed, Aug 20, 2014 at 4:38 AM, Miranda Muller psychadelic.flutterby@gmail.com wrote:
Hi there,
I am trying to design a tool that can be used to classify an incident
severity.I am using the expression - if ((${a} > ${b} and ${c}= yes), ${a}, ${b}) in
xlsform.However, even when ${a} > ${b} is TRUE and ${c}= yes is TRUE, is still
calculates the value of ${b}.I'm not sure if my syntax is wrong, or if there is a bug, but I would hugely
appreciate some help! I have attached the xlsform that I am using and
highlighted the troublesome rows in yellow.Looking forward to everyone's feedback! Thanks in advance!
Miranda
