[ODK Community] Indexed-repeat error while referencing the index
One of the problems (features?) of ODK Collect is that any change to a
field in the form will re-compute the values for all fields that depend
upon the value for that field.
In this case, it is likely that the recalculation is trying to compute a
value for 'maxConstituency' before 'districtPosition' has a value.
You likely need to wrap the maxConstituency calculate in an if() expression
testing for a null value for that:
if(/district_min_list/districtPosition = null, '', ...original
expression... )
The test for null may need to be changed to test for zero (or perhaps both).
ยทยทยท On Tue, Jun 23, 2015 at 12:41 AM, Mero Raja Prasad Pradhan < merorajaram@gmail.com> wrote:
I'm working on a cascading select list that ultimately allows to select
another field based on the position of the selected field, but i'm having
an error.
On the calculate expression as follows:
calculate="indexed-repeat(instance('districts')/root/item/constituency ,
instance('districts')/root/item[developmentRegion=
/district_list/developmentRegion and zone= /district_min_list/zone and
district= /district_min_list/district]
,/district_min_list/districtPosition)"
This bring up an error while
district= /district_min_list/district] ,1)"
But this doesn't bring up error but the position is fixed and returns the
same value again and again.
Is there a way around this...
