Hi Jared,
Per the instructions at http://opendatakit.org/use/aggregate, did you
first install Java 6?
On Tue, Apr 30, 2013 at 12:12 AM, jared.hyneman@gmail.com wrote:
Hello!
As I run the installation wizard then launch the installation script (after entering email and password. The script pauses on the following message,
"Looking for Java...
Using JAVA_HOME and updating path"
I let this run for 3 hours with no progress. Any ideas on what I am missing?
Thanks for your help!
-Jared
The upload script should complete in about 2-5 minutes, depending upon your
network connection. And it has rather verbose output.
As Yaw infers, if it stops at this point, it is likely due to a bad Java
installation.
In this case, perhaps you defined a JAVA_HOME value that is no longer
correct (e.g., points to an older Java installation that has since been
removed)?
If you have already installed Java and are having this problem, try
uninstalling it; then re-installing it.
If it still doesn't work, you likely need to edit your environment
variables and delete JAVA_HOME and/or edit your PATH.
On Tue, Apr 30, 2013 at 8:14 AM, Yaw Anokwa wrote:
Hi Jared,
Hello!
message,
missing?
-Jared
