Sooo... that's my question what is "Maps" function in Collect? and is that easy to comment out?
Bob
Original message
To: opendatakit@googlegroups.com;
Dated: 7/30/2015 2:17:21 PM
Subject: Re: [ODK Community] Re: Move ODK Collect data to SD card?
Bob,
Don't think so. To use Maps, you do need to get a token that maps to
the signing key.
On Thu, Jul 30, 2015 at 2:05 PM, Bob Achgill bobachgill@gmail.com wrote:
Mitch,
Is there a work around for ..."registration of a Google Maps API
authorization token linked to that signing key."?
What would need to be commented out to disconnect Google Maps from ODK
Collect AND what functionality would be given up?
My developer guy says that setting up the Google Maps environment is a
hurdle for him.
Thanks!
Bob
Bob,
Relevant code should be here:
* Copyright (C) 2009 University of Washington
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License
* is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express
* or implied. See the License for the specific language governing permissions and limitations under
* the License.
package org.odk.collect.android.widgets;
import android.annotation.SuppressLint;
import android.app.Activity;
import android.content.Context;
import android.content.Intent;
This file has been truncated. show original
Bob
Original message
To: opendatakit@googlegroups.com ;
Bob,
the signing key.
Mitch,
hurdle for him.
Thanks!
Bob
email to opendatakit+unsubscribe@googlegroups.com .
For more options, visit https://groups.google.com/d/optout .
You don't have to set up a Maps Engine or other environment. This is just
for execution.
The key is needed for the widgets that display geopoints on a map. There
are two of those.
If you don't have the key and access grants set up correctly, nothing
breaks (everything should still start up fine), but when you try to use
those widgets in your forms (when collecting geopoints), the map tiles will
not display.
On Thu, Jul 30, 2015 at 12:44 PM, Yaw Anokwa wrote:
Bob,
https://github.com/opendatakit/collect/blob/master/collect_app/src/main/java/org/odk/collect/android/widgets/GeoPointWidget.java
that
Bob
Original message
Bob,
the signing key.
Mitch,
hurdle for him.
Thanks!
Bob
See the AndroidManifest.xml in whatever version of the source you have.
On Tue, Aug 4, 2015 at 6:28 PM, Bob Achgill bobachgill@gmail.com wrote:
What Android API level is ODK Collect written to?
Thanks!
Bob
