Corey,
I have submitted your problem to the ODK issue queue, here is a link.
http://code.google.com/p/opendatakit/issues/detail?id=708
The issue queue is the best place to document bugs so they get
resolved and the problem does not get lost. Also note that I attached
the form and log file to the issue.
If you star the issue then you will receive email anytime some makes
an update to the issue.
Also please remember that ODK is a free and kept going by a small
number of developers who do their best balancing requests from all
around the world. If something needs to be urgently fixed you can pay
someone to do it, a list of companies that have been asked to be
listed are available here: http://opendatakit.org/help/help-for-hire/
Waylon
On Mon, Oct 22, 2012 at 2:33 PM, wrote:
> On Friday, October 19, 2012 11:03:32 PM UTC-7, co...@rand.org wrote:
>> I have a form that was working fine until the update w/ build #1018 was distributed. Now, the form fails on the third item: only one of two answer choices is presented and then ODK fails and closes. I have truncated the form to include only the top of the file where the failure occurs. This truncated version works ok w/ build 1015.
>> Is anyone else having a problem w/ #1018?
>> Thanks,
>> Chris
> I have replicated the error and attached the log file for your reference.
> Should this topic be in a different group?
