It is unclear what you are trying to do.
See the available functions at
The condition would be
${otherfield} > 0
This assumes that ${otherfield} is a number or integer field.
If it is a string field, you will need to convert it to a number via
number(${otherfield}) but that can fail on non-numeric values.
The selected() function is only used for select-one and select-multiple
questions.
On Sun, Jan 17, 2016 at 7:51 AM, wrote:Hi,
I would like to condition the appearance of a certain item depending on
whether a previous one "is greater than 0"? I thought of using
selected(${question_name},'>0') in the relevant column but I get an error.
I have tried selected(number(${dev_agent}), '.>0') because I suspected a
string/numeric issue but this does not work either.Any idea?
This seems basic but I can't seem to find the solution.
