Harrison,
It sounds like the content type is not being set correctly.
I have filed an issue for someone to look at. If you want to follow
the progress "star" the issue and you will get email updates.
http://code.google.com/p/opendatakit/issues/detail?id=654
Waylon
On Sun, Jul 29, 2012 at 7:03 AM, Harrison wrote:
> Hi,
> I'm having problems uploading images through Briefcase. What I'm doing now is putting a jpg along with an xml file (which references the jpg) in a folder in the briefcase storage and then pushing it to the server. Everything works fine except when I click on the photo on Aggregate in says it's "binary data" and I can't open it. No problems when I go to "Manually Upload Submission Data" and select the jpg and xml seperately (i.e. I'm able to see the photo on the server).
> Thanks
> Harrison
Followed up in the issue Waylon opened.
On Sun, Jul 29, 2012 at 12:18 PM, W. Brunette wrote:
Harrison,
Waylon
Harrison
