Your change would work as long as you never jumped back into the form via
the Hierarchy view. Otherwise, the size()-1 would be referring to the last
group entered, and not the group that is the true parent of the nested
group you're in.
On Fri, Sep 21, 2012 at 3:55 PM, wrote:
I'd like to be able to run calculations on a form and do them within a
repeat. When going to the second repeat item on ODK Collect, JavaRosa has a
problem with trying to figure out what node to work with:
XPath Evaluation: type mismatch
nodeset has more than one node [...]; cannot convert to a value
A quick dive into JavaRosa and I notice that I can change this function:
org.javarosa.xpath.XPathNodeset.java:
public Object unpack () {
if (size() == 0) {
return XPathPathExpr.unpackValue(null);
} else {
return getValAt(size()-1);
and everything will work properly. I figured there would be an issue when
going back and editing the form, but none found. Is there a reason why this
wouldn't be a fix for doing calculations within repeats? I'm sure I'm
missing something here but I can't seem to find where this will cause an
issue. Let me know if you find an issue with this.
group you're in.
if (size() == 0) {
} else {
I thought that is where I would find the problem but even after navigating
back it is still working fine on my version...Odd but oh well, I knew
something wasn't right here. I'll see what I can do to fully address the
issue and submit a patch.
Thanks again,
Behr
On Friday, September 21, 2012 5:21:16 PM UTC-6, Mitch wrote:
> I believe it is a more serious problem with XPath evaluation. See
> http://groups.google.com/group/opendatakit/browse_thread/thread/48fb8faeb39d027a/ff0f9bd7d175fceb?lnk=gst&q=xpath+evaluation#ff0f9bd7d175fceb
> group you're in.
> Mitch
>> if (size() == 0) {
>> } else {
>> Thanks,
>> Behr
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
