The error seems pretty self-explanitory:
org.javarosa.xform.parse.XFormParseException: Select question has no choices
On Thu, Aug 23, 2012 at 8:54 PM, Mustafa Pirbhai wrote:
Hey Guys,
Decided to use ODK Build to make a Survey. Exported the output to .xml and
uploaded that to Aggregate and got a parsing error. Used ODK Validate and
got the following errors. (Attached files)
Any idea on whats going wrong? This file is straight from ODK Build, no
changes.
Please help
Mustafa
Mustafa,
That happened to me too. I just forgot to add the Choose One options.
Mitch, however, I got errors trying to use the form (Built export to XML
save to USB connected tablet) when I used the revelance condition *sex='0' *in
ODK Build. Once I went back and changed it to /data/sex='0' it worked. I
swear that I didn't have to explicitly include the path */data/ *at other
times. Is there an explanation?
Curtis
2012/8/24 Mitch S
<select1 ref="/data/FertilizerBuy">
<label ref="jr:itext('/data/FertilizerBuy:label')"/>
<hint ref="jr:itext('/data/FertilizerBuy:hint')"/>
</select1>
On Thu, Aug 23, 2012 at 8:54 PM, Mustafa Pirbhai info@tgharusha.comwrote:
Hey Guys,
and uploaded that to Aggregate and got a parsing error. Used ODK Validate
and got the following errors. (Attached files)
changes.
Please help
Mustafa
Curtis BRODERICK
Head of training and user support
Tél : + 33(0)1.53.02.40.61 06.15.33.57.37
Health Information System
-----------------------www.epiconcept.fr------------------------
Ce message et toutes les pièces jointes sont établis à l'intention
exclusive de ses destinataires et sont confidentiels.
Si vous recevez ce message par erreur, merci de le détruire et d'en
avertir l'expéditeur.
The information contained in the Email and any attachments is
confidential and intended solely and for the attention and use of the
named address(es). It may not be disclosed to any other person without
the express authority of EpiConcept, or the intended recipient, or
both.
If you are not the intended recipient, you must not disclose, copy,
distribute or retain this message or any part of it.
The failure to recognize this syntax and a related regression in the
javarosa library will be fixed in an update to ODK Aggregate and ODK
Collect that we're working on.
With the addition of the cascading select support using extra
sections, the way relative paths are interpreted has become much more
important to get right, because a relative path might refer to one of the
other instance sections. There are likely to be other subtle errors around
this area. The inability to use cascading selects within repeat groups is
an example of one of these subtle errors.
On Fri, Aug 24, 2012 at 8:50 AM, Curtis Broderick <c.broderick@epiconcept.fr wrote:
Mustafa,
*in ODK Build. Once I went back and changed it to /data/sex='0' it
worked. I swear that I didn't have to explicitly include the path */data/
*at other times. Is there an explanation?
Curtis
2012/8/24 Mitch S mitchellsundt@gmail.com
</select1>
Hey Guys,
changes.
Please help
Mustafa
Curtis BRODERICK
Ce message et toutes les pièces jointes sont établis à l'intention exclusive de ses destinataires et sont confidentiels.
Si vous recevez ce message par erreur, merci de le détruire et d'en avertir l'expéditeur.
The information contained in the Email and any attachments is confidential and intended solely and for the attention and use of the
named address(es). It may not be disclosed to any other person without the express authority of EpiConcept, or the intended recipient, or both.
If you are not the intended recipient, you must not disclose, copy, distribute or retain this message or any part of it.
Hey guys,
I actually picked up that right after I posted. However I still get the
errors in the ODK Validate. I decided to scrap everthing and redo the whole
thing in XLSform. More work now but might be easier in the long run.
Thanks for the replies.
Mus
> Mitch
> On Fri, Aug 24, 2012 at 8:50 AM, Curtis Broderick <c.bro...@epiconcept.fr wrote:
>> Mustafa,
>> *in ODK Build. Once I went back and changed it to */data/sex='0'* it
>> Curtis
>> 2012/8/24 Mitch S <mitche...@gmail.com >
>>> On Thu, Aug 23, 2012 at 8:54 PM, Mustafa Pirbhai <in...@tgharusha.com wrote:
>>>> Hey Guys,
>>>> changes.
>>>> Please help
>>>> Mustafa
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
>> *Curtis BRODERICK*
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
