Thanks Waylon for the detailed steps.
Apparently my issues were not limited to the way I was uploading the data,
but in addition to the memory allocated to Tomcat. Tomcat was using the
default 128MB allocated to it and it was crashing while I was trying to
upload attachments of ~8MB and greater.
Doubling the allocated memory to Tomcat did solve this problem, and in
addition uploaded the forms the correct way.
Thanks all for the answers and your help.
Regards
Kihara Absolomon
On Tue, Jun 5, 2012 at 7:54 AM, W. Brunette wrote:If you are trying to manually upload a submission to Aggregate then
assuming you have form permissions and are using the current version
of Aggregate.Goto the "Form Management" Tab and the "Submission Admin" sub tab you
will see a button called "Manually Upload Submission Data". When you
click on that button a pop called 'Submission Upload' will appear.On the 'Submission data file' point the browser at the submission xml
On the 'Associated data file(s):' point the browser at the media
files. NOTE: you can select multiple files at once using the
Associated data file file picker.Waylon
On Mon, Jun 4, 2012 at 8:54 PM, Kihara Absolomon soloincc@gmail.com wrote:
Wow! Thanks a lot for the pointers. The metadata thingie is soo cool.
again.What do I do with the partially uploaded submissions? I have tried to
zip an
instance folder and uploading it but it fails. Zipping the photos on
their
own while the form is uploaded as a plain xml also fails!How should I upload these partial submissions?
Regards
Kihara AbsolomonOn Tue, Jun 5, 2012 at 2:50 AM, Mitch S mitchellsundt@gmail.com wrote:
The correct solution is to define an in your form.
That instanceID will be used to merge the multiple submissions
necessary toupload the data. The form submission is already effectively a zip of
thedata. The problem comes when that data is very large. The larger it
is,the more likely the transmission will fail, and the more resources are
needed on the server to handle the data in one pass. By explicitly
providing an instanceID, the data can be sent in smaller chunks and
mergedon the server.
This mechanism is defined here:
group in your form.
https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaMetaDataSchema
For ODK Aggregate, you don't need to specify the namespace, just have aWith ODK Collect 1.1.7 and later, the bind for the instanceID would be:
...You can construct your own instanceID expressions. However, you should
avoid symbols and punctuation other than colons and dashes since the
parsinglogic within Aggregate is likely fragile if you go wild with punctuation
(and that is used later on when retrieving images, repeat groups,
etc.). Ifyou do construct your own values, they must be less than 80 characters
long(a limitation of ODK Aggregate) and must be unique across all devices
andsubmissions.
On Mon, Jun 4, 2012 at 3:42 PM, Kihara Absolomon soloincc@gmail.com wrote:
Hi Mitch,
Thanks for the heads up. Surprisingly I had never noticed this tab or
just didn't know its function prior to this! But we have some problems!It seems that something weird happened during submissions. Under the
Submissions Admin Tab, I have 2 instances each of my un-submitted
form. Ican see clearly that duplicate instances data is identical, down to
the autoinserted device-id, start-time and end-time. The only discrepancy
comes inthe media data collected. Each instance is meant to have a minimum of 5
photos and a no maximum, as there is a looping logic to add as many
photosas possible. These photos have been split between the duplicate
instances,in that some photos appear in one instance and not in the other and
viceversa. This is a perfect case of merging the duplicate instances. I
guess Ihave to do this at the DB level.
I don't know how many have experienced this scenario, but I think it
makes the case for the merge feature in case of in-complete
submissions.On another note, I tried using the "Manually Upload Submission Data"
function as a 2nd option, but it only offered 1 option of uploading the
media files. On using this feature, I ended up with an incomplete
instanceagain!
This can be solved by zipping all the media files and uploading them
as azip file and doing the un-zipping and merging on the server
side...just athought!
Regards
Kihara AbsolomonOn Mon, Jun 4, 2012 at 9:05 PM, Mitch S mitchellsundt@gmail.com wrote:
On Aggregate, these submissions may have been determined to be
incomplete -- this occurs if the captured media attachments for the
filled-in form were not all successfully uploaded. You can look at
incomplete submissions on the Forms Management / Submission Admin
tab. Ifyou "Mark As Complete" the form, that action will remove all traces
of themissing attachments. Alternatively, on that tab you can "Manually
UploadSubmission Data" and navigate to the phone's /sdcard/odk/instances
directory, into the directory of the incomplete submission, and
manuallyupload the submission's xml file and missing media attachments to
completethe submission.
Once the submission is complete, it will move to the Submissions tab
anddisappear from the Submission Admin tab.
If you are using an older version of ODK Collect, it may be that the
media file formats were not recognized by that older version (1.1.5
andearlier).
On Mon, Jun 4, 2012 at 8:42 AM, Kihara Absolomon soloincc@gmail.com wrote:
Hi all,
I have some instances which were marked as finalized and ready to be
uploaded to the server. During the upload process there was some
sort oferror and 6 of them weren't uploaded. I re-uploaded them and ODK
reportedthat they were uploaded successfully. However on logging in to
aggregate,the 6 instances are not reflecting in Aggregate and on Collect they
are notappearing as instances that can be uploaded. I can still see them
under theinstances folder in the SD card.
How do I re-upload them to the server?
Regards
Kihara Absolomon--
mitchellsundt@gmail.com--
