Hello, I am having problems trying to export this ODK form to Aggregate.
This is the error message I get:
{"error":"Something went wrong when trying to post to Aggregate."}
I was a able to successfully export a test form but still can't export the
form I need. We are using v0.9.4. Please let me know if you need any
additional information.
thanks, bryse
Commissioning.xml (6.66 KB)
Hi Bryse:
This is a bug with the Build exporter; it's not clever about handling entities. You can see that there is an & in your prompt; it should be escaped to & when Build exports it. I'm currently on vacation so I don't have time to fix it right this minute, but give me until tonight (pst) and I should be able to check in a fix for it.
—Clint
On Mar 4, 2011, at 9:44 PM, Bryse Gaboury wrote:
Hello, I am having problems trying to export this ODK form to Aggregate. This is the error message I get:
I was a able to successfully export a test form but still can't export the form I need. We are using v0.9.4. Please let me know if you need any additional information.
thanks, bryse
<Commissioning.xml>
