http://opendatakit.org/help/training-guides/ has a ton of information
about how to deploy ODK, and it'll give you some insight into what you
may need to implement your survey. The short answer is that whether or
not you need technical support depends on the capabilities of your
team in the field. Designing a basic form, setting up a server and
putting the forms on the phones don't require a lot of technical
experience. If you find that you need help beyond what the website and
mailing list provide, then consider hiring help at
http://opendatakit.org/help/help-for-hire/.
As far as alternatives, there are lots of other data collection
systems you might want to consider. What you pick depends on what you
need. We keep a list of the ones we know about at
http://opendatakit.org/help/faq/. See the "Are there other data
collection systems I should consider?" question. Hope that helps!
> I’m a research coordinator from X University, and we’re looking to
> launch a survey in India with a team of 30 surveyors and tablets. We’ll have
> 4 different surveys, and we anticipate collecting around 4000 responses. It
> seems as if this platform would be great for us, but I’m unsure if we need a
> tech support team there or if I can handle managing the data from here in
> NYC and what qualifications I would need to do so. Do you think ODK is
> something that would work for us? I’m also looking into using epicollect,
> which seems less well developed than ODK, and rollapoll, which charges for
> their services. Do you have any other suggestions for platforms that would
> work for us?
I think Yaw is being unnecessarily modest in this response. I would
suggest that ODK is by far the best tool you could use for a survey using
Android devices. Nothing else comes close. Its probably the best tool for
this space period and I've evaluated a lot of them over the past 10 years.
There's just no need to re-invent the wheel. They've done it.
As to your specifics: 30 devices and 4000 surveys is not a big deal. My
current use of ODK involves more devices than that and 300 data forms per
day (at least) continuously for many months in a remote part of the globe.
Other projects that have been on the ODK platform have had larger surveys
as well.
So, get started is my advice. You can probably do a proof of concept
using ODK: Build, then Aggregate, and Collect in a couple of hours. The
setup skill is mostly in following the slightly technical instructions. In
terms of managing things, I don't have a technical team on site and I don't
think you need one; if just one person on your team in India is savvy
about smart phones (like how to download apps and manage wifi settings),
you probably have enough tech support there. Further, once you have a
proof of concept you may want to retain one of the consultants Yaw
references - and you'll be better informed about what you want. As a final
thing the survey structure ("branching" logic in the questions, multiple
choice, etc) is important to mesh with the survey methodology and that's
where most projects seem to spend their time iterating - getting the exact
right set of questions and choices.
If you have an Android phone now you should download ODK Collect from the
Market (aka google Play), and look at some sample forms.
If after you go through the instructions you have a specific question -
I'll try to answer it on this thread, or someone else will....its a pretty
good place to get help until you get to the specific questions about your
own survey design - at which point its DIY or hire a consultant. I'm
trying to help, hope that is clear.
James (not associated with the UW or ODK project except as a supporter)
have
It
need a
for
would
work for us?
James Dailey
skype: jdailey
James,
Thanks so much for the strong endorsement! I still think we have much
more to do to make the process of data collection even better, but
emails like this make the work a little easier.
Thanks again,
> Other projects that have been on the ODK platform have had larger surveys as
> well.
> So, get started is my advice. You can probably do a proof of concept using
> ODK: Build, then Aggregate, and Collect in a couple of hours. The setup
> skill is mostly in following the slightly technical instructions. In terms
> of managing things, I don't have a technical team on site and I don't think
> you need one; if just one person on your team in India is savvy about smart
> phones (like how to download apps and manage wifi settings), you probably
> have enough tech support there. Further, once you have a proof of concept
> you may want to retain one of the consultants Yaw references - and you'll be
> better informed about what you want. As a final thing the survey structure
> ("branching" logic in the questions, multiple choice, etc) is important to
> mesh with the survey methodology and that's where most projects seem to
> spend their time iterating - getting the exact right set of questions and
> choices.
> If after you go through the instructions you have a specific question - I'll
> try to answer it on this thread, or someone else will....its a pretty good
> place to get help until you get to the specific questions about your own
> survey design - at which point its DIY or hire a consultant. I'm trying to
>> > have
>> > It
>> > need a
>> > in
>> > epicollect,
>> > for
>> > would
>> > work for us?
> James Dailey
> skype: jdailey
Try out this mobile data collection decision tool. It will help you figure
out what software will work for you. humanitarian-nomad.org/?page_id=533
Curtis
On 29 Mar 2012 03:10, "Yaw Anokwa" wrote:
James,
Thanks again,
for
years.
My
globe.
surveys as
well.
using
terms
think
smart
concept
you'll be
structure
to
choices.
I'll
good
to
We’ll
have
responses.
It
need a
in
is
epicollect,
for
would
work for us?
James Dailey
skype: jdailey
