I am running attached End_of_Day_Cleanup.xml form
form loads, runs, saves fine the first time
Second time I try to load form I get the "the application ODK Collect (process org.odk.collect.android) has stopped unexpectedly..."
I replicated this on 2 devices: LG550, LGe730
interestingly, when I tried it on an Asus Transformer Pad TF300TL the error didn't occur.
I loaded CatLog as suggested in another thread and have attached the log file.
I'm not a tech person so I don't know how to interpret.
Can someone tell me what I'm doing wrong, or what is going wrong?
thank you - dan
End_of_Day_Cleanup.xml (373 KB)
Catlog_ODK_End_of_Day_06212013.txt (46 KB)
The problem:
06-21 11:29:48.021 E/AndroidRuntime(1709): Caused by:
java.lang.StackOverflowError
It looks like this is occurring while reading in a formula definition
within your form.
The most likely cause is the largest of your formulas, the 'relevant'
condition on your 'level4_Group'
Split this formula into two parts, each computed and saved as an
intermediate value using a 'calculate' prompt.
Then use the resulting 2 intermediate calculate expressions in the relevant
condition.
S
tackOverflowError occurs when the expressions in a formula become very
long or complex (e.g., regular expressions).
error didn't occur.
file.
thank you - dan
It worked, thank so much for the help
Thank you Mitch, I will try splitting into two parts
