While there are simple visualizations available in ODK Aggregate, there
are far better visualization tools out there.
We recommend publishing data into Google Fusion Tables then setting up a
view https://support.google.com/fusiontables/answer/171206?hl=en to
create the dataset combining the data from the two or more forms.
If your original form has repeat groups, we create a simple view
demonstrating this technique (if you have nested repeat groups, we don't
handle those).
On Mon, Mar 23, 2015 at 12:34 PM, Nikki w nikk...@gmail.com wrote:
Also, is there a way I can link forms to perform visualizations if there
is a common value in two forms?
On Friday, March 20, 2015 at 8:08:57 PM UTC-6, Mitch Sundt wrote:
This functionality is not in the standard ODK 1.x tools.
The csv mechanism is for slowly changing or static lists of choices.
You might look at Survey CTO, which has made some extensions to support
this usage.
The ODK 2.0 tools (not yet released) are focused on supporting follow-up
surveys and dynamically shared information among a group of data collectors.
On Thu, Mar 19, 2015 at 4:51 PM, Nikki w nikk...@gmail.com wrote:
I am testing out the ODK platform and I have a question. I haven't come
across any documentation saying if it is possible to preload a dropdown for
e.g. from existing data that is already in ODK aggregate. I'm using XLSForm
to build forms. I see there is an option through csv but there may be
information that is not known before hand.
Any recommendations on how I can proceed???
Have anyone used ODK for collecting data related to livestock predation?
Please help...
Groups "ODK Community" group.
mitche...@gmail.com
mitche...@gmail.com
Thank you.
