ODK Installation error
Hi and happy 2013
My installation fails at the Launch Installation Script step with the
error messages below. The computer is a Macbook running Windows 7 Ultimate
32 bits and Java 7 update 10, with the antivirus off.
When I paralel install on a 64 bit windows Ultimate computer with the same
setup, I don't get this error.
The file I am executing is ODK Aggregate v1.2.0 osx-installer.app.zip
from http://code.google.com/p/opendatakit/downloads/list
Please advise on how to get around this problem.
Thank you
https://lh5.googleusercontent.com/-3JVcYkcXqRs/UOsuIqhPUSI/AAAAAAAAAA0/P01zw7JHF7o/s1600/error.png
I post the same message with a more specific title to see if anybody run
into the same problem.
Thank you
I'm confused. You say you're running Macbook, but then say it is a Windows
32 bit installation. Which is it?
Also, I don't see the error message.
··· On Mon, Jan 7, 2013 at 12:29 PM, Santiago Arnalich < coordinacion@arnalich.com> wrote:
Hi and happy 2013
Thank you
If you are running this in Windows operating system (regardless of the
hardware you are running it on), you need to download the Aggregate
installer for Windows (not Mac).
from http://code.google.com/p/**opendatakit/downloads/listhttp://code.google.com/p/opendatakit/downloads/list
Thank you
Excuse me, that was a copy-pasting mistake.
The file I install is for Windows (ODK Aggregate v1.2.0 windows-installer),
but I get that error nevertheless
same setup, I don't get this error.
The file I am executing is ODK Aggregate v1.2.0 osx-installer.app.zip from
Thank you
http://www.arnalich.com/
Santiago Arnalich
Consultant, lecturer and author
+34 671700686
skype: sarnalich
www.arnalich.com
Consultancy & training for Development
It looks like the installer cannot determine/remember where your home
directory is.
After the script fails and you exit the installer, what happens if you
double-click the .hta file to run it?
··· On Wed, Jan 9, 2013 at 9:39 PM, Santiago Arnalich <coordinacion@arnalich.com wrote:
windows-installer), but I get that error nevertheless
Thank you
Santiago Arnalich
+34 671700686
skype: sarnalich
www.arnalich.com
If I click the hta as you suggest I get the same non Win32 error, but the
second message is no longer there
directory is.
On Wed, Jan 9, 2013 at 9:39 PM, Santiago Arnalich < coordinacion@arnalich.com> wrote:
run into the same problem.
the error messages below. The computer is a Macbook running Windows 7
Ultimate 32 bits and Java 7 update 10, with the antivirus off.
Thank you
Santiago Arnalich
+34 671700686
skype: sarnalich
www.arnalich.com
Santiago Arnalich
+34 671700686
skype: sarnalich
www.arnalich.com
Somehow the .hta file extension is not correctly mapped to this executable:
C:\Windows\System32\mshta.exe
Right-click, choose 'Open with', select 'Choose default program...' and
navigate to that file; check the 'Always...' checkbox and click 'OK' to
launch.
Ref:
http://social.msdn.microsoft.com/Forums/is/tfssetup/thread/e75e5adb-7889-4f4d-8492-13332b46e698
··· On Thu, Jan 10, 2013 at 11:49 AM, Santiago Arnalich < coordinacion@arnalich.com> wrote:
directory is.
The file I am executing is *ODK Aggregate v1.2.0 osx-installer.app.zip
Thank you
Santiago Arnalich
+34 671700686
skype: sarnalich
www.arnalich.com
Santiago Arnalich
+34 671700686
skype: sarnalich
www.arnalich.com
Thanks a lot Mitch, that solved it.
Santiago Arnalich
+34 671700686
skype: sarnalich
www.arnalich.com
Hi Mithc,
I just saw you solved Kelba's problem. I have exactly the same problem but I don't understand the process you're telling him to do:
( Somehow the .hta file extension is not correctly mapped to this executable: C:\Windows\System32\mshta.exe
Right-click, choose 'Open with', select 'Choose default program...' and navigate to that file; check the 'Always...' checkbox and click 'OK' to launch.
Ref: http://social.msdn.microsoft.com/Forums/is/tfssetup/thread/e75e5adb-7889-4f4d-8492-13332b46e698 )
Could you repeat it for me as I was a child?
Thank you very much,
Xavi Enrich
In his screenshot, It says that some hta file is not executable. you should
go to that file, right click it, an do shit.
IF you dont have mshta.exe, there is an installer somewhere on microsoft
website.
··· El miércoles, 4 de febrero de 2015, 9:35:29 (UTC-3), xavier...@gmail.com escribió: > > Hi Mithc, > > I just saw you solved Kelba's problem. I have exactly the same problem but > I don't understand the process you're telling him to do: > > ( Somehow the .hta file extension is not correctly mapped to this > executable: C:\Windows\System32\mshta.exe > > Right-click, choose 'Open with', select 'Choose default program...' and > navigate to that file; check the 'Always...' checkbox and click 'OK' to > launch. > > Ref: > http://social.msdn.microsoft.com/Forums/is/tfssetup/thread/e75e5adb-7889-4f4d-8492-13332b46e698 > ) > > Could you repeat it for me as I was a child? > > Thank you very much, > > Xavi Enrich
You need to have Internet Explorer installed to be able to open HTA files.
This is a Microsoft Windows issue -- search their site for this: HTA not
opened
should go to that file, right click it, an do shit.
website.
Hi Mithc,
launch.
Xavi Enrich
