Hi there,
I'm experiencing some difficulties with exporting my ODK Scan form. Each
time I try to export the form, nothing happens. Can you please advise? I've
attached a few screen shots for you.
Many thanks in advance!
Hi there,
Hi Jaron,
Your message revealed a bug that I have hopefully fixed. Please try it now
and hopefully it will work for you.
If that doesn't fix it, there are a few possibilities that might cause a
form to fail to export, but the most common is an invalid name. Field names
must begin with a letter and contain only letters, digits, and '_'
(underscores). Please check to make sure all your field names meet these
guidelines (this includes subform/group names). For example "3MonthCheckup"
is invalid but "Month_3_Checkup" is fine.
If that doesn't fix it you can send me the saved form and I'll take a look.
Regards,
Jeff Beorse
jbeorse@cs.washington.edu
Hi there,
attached a few screen shots for you.Many thanks in advance!
Jaron Reed Goddard, MPA
Co-Chair | Seattle Women's Commission
C. 360.335.7234
E. jaronelizabethreed@gmail.com--
