ODK shapefile tracing
Hi ODKers,
can ODK be built to trace a shapefile on a base map? And enable that
shp/kml/etc. be exported
Bernie
Hi Bernie,
This issue was just discussed a few days ago. See
https://groups.google.com/d/msg/opendatakit/RqrqBJqSNLY/nzgExR3qa6AJ.
··· -- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.
On Thu, Sep 5, 2013 at 5:11 AM, Bernard Wright bernard@geogecko.com wrote:
Hi ODKers,
Bernie
Hi Bernie
we are testing http://blog.smap.com.au/ at the moment to do this, it uses
an odk form as its basis, which means no more learning for us, and collects
the shapefile as a string/group of individual gps points and one uploaded
to their system it creates the polygon. For us it tackles the problem of
saving a shape file together with meta data and it also does this for
multiple shape files recorded by many users all as one data layer. It then
allows export to a gis package like arc info or gooles earth builder.
its looking good so far
Jon
··· On Thursday, September 5, 2013 1:11:52 PM UTC+1, Bernard Wright wrote: > > Hi ODKers, > can ODK be built to trace a shapefile on a base map? And enable that > shp/kml/etc. be exported > Thanks > Bernie >
