Hello all,
I just wanted some clarification here. What is the difference between ODK
Survey and ODK Tables? How are they related,if at all?
Thanks in advance,
Tumaini
Hello all,
Thanks in advance,
Tumaini
Hi Tumaini,
Hello all,
You can find information on ODK Survey here:
http://opendatakit.org/use/beta/survey/ and ODK Tables here:
http://opendatakit.org/2013/07/odk-team-releases-odk-tables-alpha/
Thanks and Regards
Ronald Munjoma
Thanks in advance,
Tumaini--
Hi, Can you help me for how can build and work odk table?
In a nutshell:
ODK Tables -- provides access to an entire dataset, with spreadsheet views,
exports to CSV, and visualizations (scatter plots, bar graphs, line graphs,
etc.). A subset of ODK Aggregate, with better visualizations, all on your
device. Share the data you need across devices and users.
ODK Survey -- provides HTML-based forms for entering one submission / row
into the tables that are visible from ODK Tables. A more flexible, more
powerful ODK Collect with direct access to a local database for filtered
selection lists, relational associations across forms and tables,
user-directed form navigation, and, if desired, dynamic AJAX queries back
to a webserver to retrieve realtime information.
Both apps will support fully customized HTML landing pages, enabling
branding and customizations specific to an organization; only the
configuration and app synchronization screens are not customizable (and can
be hidden with administrative controls). A goal in our design is to
eliminate most needs for forking the ODK codebase for app customization.
Hi Tumaini,
On 9 December 2013 10:06, Tumaini Kilimba tkilimba@ihi.or.tz wrote:
Hello all,
Survey and ODK Tables? How are they related,if at all?You can find information on ODK Survey here:
http://opendatakit.org/2013/07/odk-team-releases-odk-tables-alpha/Thanks and Regards
Ronald MunjomaThanks in advance,
Tumaini--
Thanks, that made it all clearer! Great work!
In a nutshell:
views, exports to CSV, and visualizations (scatter plots, bar graphs, line
graphs, etc.). A subset of ODK Aggregate, with better visualizations, all
on your device. Share the data you need across devices and users.ODK Survey -- provides HTML-based forms for entering one submission / row
to a webserver to retrieve realtime information.Both apps will support fully customized HTML landing pages, enabling
eliminate most needs for forking the ODK codebase for app customization.Mitch
On Mon, Dec 9, 2013 at 1:30 AM, ronald munjoma simbiso@gmail.com wrote:
Hi Tumaini,
Hello all,
ODK Survey and ODK Tables? How are they related,if at all?You can find information on ODK Survey here:
Tumaini--
Groups "ODK Community" group.
mitchellsundt@gmail.com--
Documentation for getting started with Tables can be found at
https://opendatakit.org/use/2_0_tools/odk-tables-2-0-rev126.
Clarice
On Monday, December 9, 2013 at 2:06:43 PM UTC+6, Tumaini Kilimba wrote:
Hello all,
ODK Survey and ODK Tables? How are they related,if at all?Thanks in advance,
Tumaini
Yes, helpful for all readers to get it in a nutshell. Thanks Mitch.
