Be sure the "choices" sheet in your Excel file has a "name" column and that
every row has a value under this "name" column; the values in the "name"
column will be the "value" field in the form definition file (the XML file
produced by XLSForm). Refer to the sample Excel file on the XLSForm page ( http://opendatakit.org/use/xlsform/ ) for how the choices sheet should
appear.
Once you make the changes in your XLSForm, the generated XML file should
run through the latest ODK Validate without an error. Download the latest
ODK Validate from here: http://code.google.com/p/opendatakit/downloads/list
Running it will show you where the problems are.
On Fri, Aug 3, 2012 at 4:49 AM, Burimwaka Misaki wrote:
Hi
Am struggling to upload my converted xform into the odk aggregate server.
Have realize there are missing values in every choice label,could any one
help.
I could insert the value manually but the file is huge.
NB: Am converting the xls file using the xlsform converter
Hi Nathan - this issue is the same as mine, the trailing space after the
word "name" for Imobi.
Thanks for sorting it out. Burimwaka and I are working together.
On Fri, Aug 3, 2012 at 8:47 PM, Nathan wrote:
Hi Burimwaka,
If your problem continues could you post your XLSForm to the mailing list
or send it to me to take a closer look?
-Nathan
