ODK xlsform offline
An older version of xlsform offline (version with drag and drop interface) stopped converting forms. The black screen appears and disappears in seconds and output folder is empty (this started only this morning).
So I downloaded newer version first v1.7.0 then v1.6.0 after nothing happens when I choose xlsform for conversion and specify destination folder and hit run. The run button is greyed out, but form isn't converted even after waiting more than 10 minutes.
ODK xlsform v1.6.0
Hi @Louis_Omoya! A couple of questions for you...
  1. What operating system are you using?
  2. Can you upload your form to this topic so we can try to reproduce the problem?
  3. Does the online tool at http://opendatakit.org/xlsform/ work?
Hi Yaw, ODK Offline started working a couple of hours later.
  1. Windows 10
  2. I resorted to the online tool and it worked perfectly.
Louis
