ODK XLSForms Problem
Hello ODK Group,
I´m having issues with XLSForms converter. at this url:
http://opendatakit.org/use/xlsform/
I Update Java, I Usually use Chrome, I tried with Explorer 10, it seams the
connection between browser and server is lost.
do you have any feedback
best regards,
Tomás Albesano
310 5618908
Bogotá Colombia
Tomás,
The server is in Seattle and it's still very early here. I'm sure when
the core team wakes up, and has the time, they'll take a look.
pyxform, the library that does the XLS conversion, runs offline. I'd
recommend you install that and rely on that instead. See
https://github.com/UW-ICTD/pyxform and
https://github.com/UW-ICTD/xlsform.exe/blob/master/README.md to get
started.
On Tue, Aug 12, 2014 at 6:53 AM, Tomas Albesano tomasalbesano@atiemppo.co wrote:
Hello ODK Group,
best regards,
Tomás Albesano
310 5618908
Bogotá Colombia
