Yaw,
Thanks.
I was able to get an Excel Expert to help with a UTC date & time
function conversion.
The purging works.
On 4/3/14, Yaw Anokwa wrote:
> 1. You can purge data by date in Aggregate. Go to Form Management,
> then Submission Admin, then select the form and press Purge Submission
> Data. It will give you a date option. Try this with a test form first
> before trying on your live data.
> 2. Sounds like a bug. File a bug report at
> https://code.google.com/p/opendatakit/issues/list and be sure to
> include the version of Aggregate you are using.
> 3. Correct. There is no easy way to filter using dates. File a feature
> request at https://code.google.com/p/opendatakit/issues/list and maybe
> someone will build it.
> 4. Long standing feature request. Code contributions welcome at
> https://code.google.com/p/opendatakit/issues/detail?id=554.
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> On Wed, Apr 2, 2014 at 4:38 AM, Olubunmi Junaid wrote:
>> Hi all,
>> 1. How can I do multiple delete of submissions on my Aggregate? I have
>> over
>> 5000 submissions and I don't want to remove form while collectors are
>> still
>> on field.
>> 2. My submissions per page changes back to 100 each time I change it.
>> 3. There is no way I can filter submission date and time for my
>> timestamped
>> form.
>> 4. I wish I can also get help with my date and time format and not UTC
>> format.
>> Thanks
>> "ODK Community" group.
>> email to opendatakit+unsubscribe@googlegroups.com.
> You received this message because you are subscribed to a topic in the
> Google Groups "ODK Community" group.
> To unsubscribe from this topic, visit
> https://groups.google.com/d/topic/opendatakit/1a_e2sINTbI/unsubscribe.
> To unsubscribe from this group and all its topics, send an email to
Junaid Olubunmi
