ODK Collect allows the use of alternates to ODK Aggregate such as OpenMRS. Which version(s) of OpenMRS (plus recommended version of XFORMS and other modules integral to ODK Collect) are compatible and what are the parameters for downloading and uploading xforms). We have managed to download and complete forms but have not been able to upload them.
Although the version of ODK Clinic in the repository is unsupported can anyone advise which version of OpenMRS and appropriate Modules/Versions to use.
This is a long standing issue
(https://code.google.com/p/opendatakit/issues/detail?id=374). Daniel
Kayiwa and Sam Mbugua are probably the two people who might know. If
you do figure it out, perhaps you can update the issue linked above?
The latest version of xforms module will work with collect.
For you to upload there are configurations you need to do on the server
side; Kayiwa is the best person to respond on that.
Also there is odkClinic which is a helper app that sits as an interface
between collect and openmrs of-course giving you more
functionality and patient access.
(https://www.youtube.com/watch?v=za-On8FlrWs).
Sam Mbugua
On 02/03/2014 01:51 AM, Yaw Anokwa wrote:
> Hi Terry,
> Thanks,
> Yaw
I'm interested in this topic, am undergoing a study currently and i'm using
ODK Clinic v1.0.apk trying to connect it to OpenMRS ver 1.8.3 and intent to
use xForms Module. So i was wondering if anyone can help me go through the
process will really appreciate it.
