Hi
I will be doing a survey with no data connection as the locations are very
remote and we will require GPS for the survey. Is there any way to get a
location without any data connection?
Bashir
Hi
Bashir
I don't think there should be a problem.
Just to make sure and see for yourself, you can turn off mobile data and WIFI (Airplane mode) and see that you fill surveys with GPS reading, and there's no problem with it.
A potential problem could be, it takes longer time to obtain locations
Just make sure to verify the specs of your device full GPS is supported,
and not just "A-GPS" or assisted GPS that requires a data connection.
Hi
location without any data connection?Bashir
This email is free from viruses and malware because avast! Antivirus
http://www.avast.com/ protection is active.--
<javascript:_e(%7B%7D,'cvml','opendatakit@googlegroups.com');>
<javascript:_e(%7B%7D,'cvml','opendatakit%2Bunsubscribe@googlegroups.com');>
email to opendatakit+unsubscribe@googlegroups.com
Nik
Need help customizing Survey Instruments/Tools/Forms for ODK Collect? Drop
me an email.
Bashir,
I'm pretty sure the Galaxy Tabs have true GPS, but you should test to make
sure because there are at least 3 devices that people call Galaxy Tab 7.
Use https://play.google.com/store/apps/details?id=com.eclipsim.gpsstatus2 to
test.
On Mon, Jun 23, 2014 at 10:55 PM, Bashir Jahed admin@osilab.net wrote:
Thanks for the responses, does anyone know if the galaxy tabs 7" supports
gps full or not?On 24 Jun 2014, at 6:48 AM, ゴー・ニコライ nikolai.go@gmail.com wrote:
and not just "A-GPS" or assisted GPS that requires a data connection.On Monday, June 23, 2014, Bashir Jahed bashir@radarmob.com wrote:
Hi
very remote and we will require GPS for the survey. Is there any way to get
a location without any data connection?Bashir
Nik
me an email.--
Thanks for the responses, does anyone know if the galaxy tabs 7" supports gps full or not?
