I was just wondering in this page regarding offline map storage on a device: https://docs.opendatakit.org/collect-offline-maps/
wether the sdcard folder it is referring to has to be external storage or internal storage since my device doesn't have a card slot
Thank you!
Yes, you are right. If your device doesn't have a card slot then the folder will be created internally. Just check your storage for the odk folder and you should be good from there.
