Offline Nafundi XLSforms tool
This is a very cool tool and was very glad to get it but I am running into an issue on some forms that had otherwise compiled using the online version of the XLSforms tool.......
I am getting
Conversion errors:
'list' object has no attribute 'startswith'
on some of these forms.........anyone have a clue?
This is due to a bug in pyxform library that XLSForm Offline uses. The
bug manifests if you are using choice_filters and likely affects
Formhub, Ona, Enketo, SurveyCTO, and Kobo.
https://github.com/XLSForm/pyxform/issues/20 has the bug report and the fix.
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
I am getting
Conversion errors:
Thanks Yaw.........The fix work great......Thanks again
