Hi friends, I try to find documentation about the hardware and software
requirements to deploy a robust (HA) solution of ODK in own datacenter but
can't find anything, can you tell me your experiences about it? also maybe
you have "Official" training about planing, design, deploy, operations,
upgrades and backup of this kind of solution?
Hello Germán,
You can find loads of information using the following links:
https://opendatakit.org/use/aggregate/deployment-planning/
https://opendatakit.org/use/aggregate/tomcat-install/
Once you determine the HW and SW requirements from above links, you can
determine HA requirements of your on-premise solution.
The group/community may tell you more about HW, SW, Training and other
requirements.
