Open questions validation
I have two open numeric questions in KoboToolbox and i want to ensure that they have the same answer for example Q2 should have the exact same numbers as the answer in Q1. Thank you
Hi @Erblina_Temaj , you can use a constraint :
${q1} = ${q2}
and a constraint message (shown if constraint is not validated)
check_answers_are_the_same.xlsx (493,3 Ko)
