Hi all
I am new to ODK and i do apologize if some of these questions are
elementary. Here is my understanding based on github, wikis etc.
- In ODK 2.0 for surveys we use JSON serialization (as opposed to XForm
XML serialization in ODK 1.x / ODK Collect). - The JSON schema is documented to some extent
in https://github.com/opendatakit/opendatakit/wiki/ODK-2.0-Form-Specification. Since
JSON is generated from XLSX, the xlslx documentation is the source of truth
to some
extent. https://opendatakit.org/use/2_0_tools/active-distribution/application-designer-rev-204/xlsx-converter-rev-204/
Here is my question. ODK Collect used Javarosa code to parse, validate XML
in the app. What does ODK Survey use to parse, validate JSON ? I am looking
in ODK Survey, androidcommon, androidlibrary code bases. I will continue
digging into the code, but would appreciate some pointers.
-Giri
