How to generate private key for ODK briefcase
i have tried running these commands but it is gives this error openssl : The term 'openssl' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
Hi, @Vineet_Jk!
It seems like you're running that on Windows. Did you install OpenSSL? There's a section explaining how to do that in the link @yanokwa has shared: https://docs.opendatakit.org/encrypted-forms/#install-openssl-windows-only
