Hi all,
ODK offers to save incomplete and complete instances using the name of the
form and the date and time stamp.
This is fine, but it adds an extra step of typing, which I usually try and
avoid as much as possible. Is it possible to have ODK offer to save a form
using a unique/particular instance or a combination of instances of the
collected data?
e.g. If I am entering information about households, and I have specified
Household Head as a unique field, ODK would offer to save instances using
the Household Head name and then add the timestamp the data was added as it
currently does.
How can I do this?
Regards
Kihara
This is a feature others have asked for (see
http://code.google.com/p/opendatakit/issues/detail?id=433).
It's not particularly difficult to do, but we haven't had the time. If
someone wants to build it, we'd be glad to include it in ODK Collect.
On Mon, May 14, 2012 at 5:35 PM, Kihara Absolomon wrote:
> Hi all,
> collected data?
> currently does.
> How can I do this?
> Regards
> Kihara
Thanks. I will take a look.
On Mon, May 14, 2012 at 5:35 PM, Kihara Absolomon soloincc@gmail.com wrote:
Hi all,
the
and
form
collected data?
it
currently does.
How can I do this?
Regards
Kihara
Hi all,
I want to take a shot at enabling this feature. I am thinking of tackling
it from the following angle:
Functionality:
- The form can/should be saved using different ways.
- Using a unique field in the form, eg using the id field, like
[id].xml In case there exists an existing entry, maybe append the end
timestamp!
- A combination of fields in the form. These should be specified
somewhere in the form, including the intended format. ie, if name and id
fields should be used, which format should the name has: No Spaces
([name][id].xml), Using an underscore ([name]_[id].xml), etc
- By a time stamp. This can be time the user started filling the form
or the time the user saves the form.
- The way the form should be saved should be specified in the form
somewhere.
Some questions:
- Is there an xml field/property that can be used for this purpose, ie
to specify the saving format?
- I have seen a function SaveToDiskTask::SaveToDiskTask under
src/org/odk/collect/android/tasks/SaveToDiskTask.java line 66. I presume
this is the function used to save the instances. Am I right?
Any pointers/help would be greatly appreciated.
Kihara
Hi all,
the
and
form
collected data?
using
as it
currently does.
How can I do this?
Regards
Kihara
The InstanceProvider has a "DisplayName" and "DisplaySubtext" that can be
modified (I think). These don't alter the directory names on the SDCard,
but they are used by the ODK Collect user interface. This is how you can
name the instance in the final "Mark as Complete" screen of the form.
I think the change would be to generate this name differently. Not sure
how you would tie this into the form definition. That sounds like a
modification to javarosa ( https://bitbucket.org/javarosa/javarosa/wiki/Home).
On Sat, Jun 2, 2012 at 3:06 AM, Kihara Absolomon wrote:
Hi all,
Functionality:
timestamp!
form or the time the user saves the form.
somewhere.
Some questions:
Kihara
Hi all,
the
and
form
collected data?
specified
using
as it
currently does.
How can I do this?
Regards
Kihara
