Hi All,
I am trying to achieve something and not sure if it is possible at the
moment with ODK. I have a repeat group of questions. One of the questions
is a picklist of names and I would like a way to ensure that all the names
are monitored. I do not want the enumerator to miss any name.
I am not sure how to logically go about this. Is ODK able to give an output
of the monitored names? So If i have 10 names on the picklist and the
repeat group is done, a follow on acknowledgement of the X out of the 10
names that have been monitored should show up.
I hope this makes sense.
Any help or pointers will be appreciated.
Kind Regards
Adah
Hi Adah,
http://opendatakit.org/help/form-design/binding/ index-repeat will let
you pull out a value from a repeat. So you could add some logic that
if a name exists and a particular value is not filled out, then alert
the user to go back and fill information for that name.
On Wed, Oct 8, 2014 at 7:13 AM, Adakole Kennedy akennedy@camfed.org wrote:
Hi All,
moment with ODK. I have a repeat group of questions. One of the questions is
a picklist of names and I would like a way to ensure that all the names are
of the monitored names? So If i have 10 names on the picklist and the repeat
group is done, a follow on acknowledgement of the X out of the 10 names that
Kind Regards
Adah
