I am struggling to create a new project using google cloud platform. I have
created a project 2 years ago for some other project and its working fine
till now. However i wanted to create another one for new project so that it
will be separate. But i am unable to do. Earlier it was very easy to create
but currently i am struggling. Once i create new project later to get the
project id code (for example: projectid.appspot.com).
These days it asking deploy on App Engine with a simple "Hello World" app.
If you're new to App Engine, then start here. I did this also but i am
unable to generate it.
On Wed, May 17, 2017 at 12:36 AM, wrote:
> Dear Users,
> Please help
> Thanks
> User
> "ODK Community" group.
I am giving you solution to all those who were not able to create project id. For example when you try to cancel the tutorial to say "Hello World", in this case just remember one thing that you have already created the project id, but its not showing. In that case open ODK aggregate software fill the details and verify the token and activate it. Thats it, the problem will be saved and now you can access your app-engine project id.
