Is there a way to average the location coordinates, e.g. take the GPS
coordinates every 5 seconds for a total of 20 times and then average the
Latitude and Longitude to store that as the record's location?
Joe
Joe
Hi Joseph,
I'm assuming you need this functionality because your GPS accuracy is
not very high? If at all possible, I'd recommend using a GPS chip
(better phone, Bluetooth connected GPS) that has better accuracy.
Assuming you can't do that, then you have to change ODK Collect's
source code to support GPS averaging. If you aren't a programmer, you
can hire one from http://opendatakit.org/help/help-for-hire/. If you
can't hire one, then file a feature request at
http://code.google.com/p/opendatakit/issues/list and perhaps someone
from the community might add it.
Hope this helps,
Latitude and Longitude to store that as the record's location?Joe
Thanks Yaw, even with high accuracy GPS units, this is a good habit to
generally get the most out of your device as I'm sure you know.
I use a 3-5m accuracy chipset and plan my data collection for low PDOP.
I'll take a look at the code and see if I can roll my own or sub the task
out. :o)
Thanks for the suggestions and helping me know that I wasn't finding it
because it wasn't there, not because I wasn't looking in the right place.
Cheers,
Joe
Hi Joseph,
(better phone, Bluetooth connected GPS) that has better accuracy.Assuming you can't do that, then you have to change ODK Collect's
from the community might add it.Hope this helps,
design, implementation support, and user training for ODK.On Sat, May 4, 2013 at 1:49 PM, Joseph Kinyon josephkinyon@gmail.com wrote:
Joseph Kinyon
415.250.1786
Note that you can specify the accuracy threshold for capturing a Geopoint
in the XML (don't think it is available via XLSForm or Build).
See: http://opendatakit.org/help/form-design/examples/#geolocation_prompts
And look at the snippet for how to lower the threshold (e.g., to 3.5 m from
the default of 5).
out. :o)
Cheers,Joe
On Sun, May 5, 2013 at 3:39 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Joseph,
Groups
an
Joseph Kinyonjosephkinyon@gmail.com
415.250.1786--
