Dear all,
In my form, I have an input widget where I want the enumerator to fill
in the interviewees ID. However to avoid Transcription errors, I want
the enumerator to confirm the ID by typing it again on the following
page and if the two ID's match then the enumerator can continue, else
a message tells the enumerator to go back and double check the entered
ID. Considering that I only want the second ID entered for comparison
and do not necessarily want to save two IDs which are exactly the same
in two different columns, how can I make the second input widget NOT
save its value, only be used to make comparisons?
Thanks in advance,
Tumaini
There is a tag that lets you specify the elements you
care to have submitted the rest are ignored (think of them as
intermediate value holders).
I am personally not clear how much of it is currently implemented in
collect, others can chime in. Here was the previous email thread on
the subject.
https://groups.google.com/group/opendatakit/tree/browse_frm/month/2011-10/78e1373cb592701d
On ODK's Xform guidelines page in stricter syntax it talks about
http://opendatakit.org/help/form-design/guidelines/ in the "Stricter
Form Syntax - ODK Aggregate 1.0" item 3 talks about the submission
tag.
We should document how to do it better in the guidelines, so I filed an issue.
http://code.google.com/p/opendatakit/issues/detail?id=578
Waylon
On Sun, May 20, 2012 at 2:09 PM, Tumaini Kilimba wrote:
> Dear all,
> Thanks in advance,
> Tumaini
Ok thanks, will have a look
> the subject.https://groups.google.com/group/opendatakit/tree/browse_frm/month/201...
> On ODK's Xform guidelines page in stricter syntax it talks abouthttp://opendatakit.org/help/form-design/guidelines/in the "Stricter
> tag.
> We should document how to do it better in the guidelines, so I filed an issue.http://code.google.com/p/opendatakit/issues/detail?id=578
> Waylon
> > Dear all,
> > Thanks in advance,
> > Tumaini
