Hi all!
I have an issue with cascading selects in my form. Do any of you know whether its possible to have a select_multiple (from external file) option for cascading selects? Or is it only feasible to select one option?
Example:
Question 1: How many communities come to X every day?
Answer: 35
Question 2: Do you know which country they come from?
Q3: which city
Q4: which area
For Q4, I would like for enumerators to select all options that apply, so they won't have to go through Q2 and Q3 again for every single of the 35 communities, which come to X every day.
Is that possible with cascading select or do you have any other suggestions? For Q4 I have up to 150 options, so I'm looking to make it as simple and easy-to-read as possible.
Thank you so much in advance!
