Pre-population with previous data in grouped repeats
We are pre-populating our xlsform with answers from a previous survey wave and have questions that repeat in a grouped repeat structure as below:
Q.1 select_one roomtype
Q.2 select_one heated_time
Q.3 select_one occupied_time
For example, a household may have 5 rooms (roomtype1, roomtype2, roomtype3, roomtype4, roomtype5) each with a different heated_time and occupied_time. I am wondering how I can pre-populate data for each repeat, corresponding to a different room for the same household? I use the pulldata() command for other variables but can only populate data for the first repeat/room with this method in the group repeat structure.
We use ODK collect with an xlsform to conduct the survey on android tablets.
Current set-up in xlsform:
Thanks in advance!
Not exactly the solution you were looking for, but a low-tech approach could be to repeat your "room " group for as many types you have, e.g. room1, room2, ..., room5.
This way the prepolutation should work.
Andrea
