Hello
Good and happy to all members of the communityexemple.docx (14.0 KB)
How to present such a questionnaire in odk
Hi @nomolos,
You can present this questionnaire by translating it into an XForm using ODK Build at https://build.getodk.org/, or an XLSForm in a spreadsheet program like Excel.
The docs at docs.getodk.org are detailed and helpful.
Have a go at that and see how far you get.
If you have specific questions about form design, don't hesitate to search the forum for possible answers, and if you can't find an answer, ask a question yourself with a detailed example.
Don't be afraid to refine the form many times until your enumerators are happy.
If you need the form designed for you, you could also try the Marketplace to hire someone.
Hope this helps to get you started, and a happy new year to you too!
