If you are playing around with the 1.1 preview release, note that it
assumes your forms start with
<?xml version="1.0"?>
If you have a form that begins with
you will have trouble upgrading to the preview release.
http://code.google.com/p/opendatakit/issues/detail?id=596
Will fix this in the final code.
To be clear, this is the ODK Aggregate 1.1 preview release.
This issue breaks forms published from Build into Aggregate. You will need
to download those forms, add the <?...?> line, then upload to ODK Aggregate
1.1 for them to work.
Hello,
Can username be inserted in a form and be filled automatically with the
username introduced in the ODK Collect Settings without to need to write
it again? Is there some widget to do it?
