This can happen if you are using an older (pre-1.4.5) ODK Aggregate and use
the "Mark As Complete" button on the Forms Management / Submissions Admin
subtab.
The partial solution is to remove these submissions from the set of
submissions for that form so that the rest of the export can complete
successfully. The directory structure of the "ODK Briefcase Storage" is
fairly straightforward:
forms/formId/instances/cleanedinstanceid/...
The cleanedinstanceid is the instance id with all colons and slashes
removed.
i.e., uuid00babe94-2e5e-4785-b2eb-521a6b1ffbc7
If you move that directory out from within the "ODK Briefcase Storage"
directory, you should be able to export the remaining submissions.
On Mon, Feb 22, 2016 at 5:58 AM, wrote:
I am using ODK Briefcase v1.4.6. I am running Java 6.
I have an encrypted form that I am trying to pull/export using Briefcase.
The form includes images and signatures.
When I pull the form, it pulls successfully.
When I export the form, it FAILS. It exports a few lines, and then it
fails.
The error given is:
Error decrypting submission uuid00babe94-2e5e-4785-b2eb-521a6b1ffbc7
Cause: org.opendatakit.briefcase.model.FileSystemException: Error
decrypting: uuid00babe94-2e5e-4785-b2eb-521a6b1ffbc7 Missing files:
FAILED!
I have pulled and exported other forms on the same server today, so it is
specifically a problem with this form.
